Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone goes to sleep after 20 min without using it
i have an iphone 6 and if you put it on the table and don't use it for about 20mins than it goes dead
only way to wake it up is to hard reboot (power button + home button)
if you use it nonstop it works perfectly
i have changed the battery and all the components (cameras, wifi antenna, lcd) still the same problem
Add a comment
1 Answer
hmm. this looks like it could be board damage. Try taking it to a repair shop that does micro soldering . They have a microscope to look at your MotherBoard . You stated you replaced all the components . The only one you didn't replace was the board. Try that and keep the rest of us in the loop with your progress!
Happy fixing!
Add a comment
Add your answer
Adrian Zymeri will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 35
