1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
Core Duo 2.0 Not Charging New Battery and Adapter.
My MacBook pro will not charge. I bought a new adapter and battery. Once the battery ran down, the computer died. The adapter shows a steady bright green light. When it is plugged in, I can hear a clicking sound if I put the laptop to my ear. I though it was the io board but the adapter is lit up. Scared it is a logic board issue.
Score -1
2 Comments
Thanks. They are: VWW
by
Apple MacBook Pro "Core Duo" 2.0 15" Specs
Identifiers: MacBook Pro - MA464LL/A* - MacBookPro1,1 - A1150 - N/A
by
Add a comment
Chosen Solution
Sounds like you may have bad MagSafe port. Please give the last three letters of your serial number so your Book can be exactly identifies and we'll get you to the correct part and guide for replacement.
UPDATE Here's how to replace the I/O board MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement
Here's the board: MacBook Pro 15" (Model A1150) Left I/O Board
MacBook Pro 15" (Model A1150) Left I/O Board Image
Product
$99.99
Score 2
1 Comment:
UPDATE
Has it gotten wet? Try reseating your battery connector to logic board cable. MacBook Pro 15" Core Duo Model A1150 Battery Connector Replacement
Also remove the battery and using a multimeter, check the output of the battery connector. If there is no output, replace the connector.
MacBook Pro 15" (Model A1150) Battery Connector
by
Add a comment
I installed the new board and it now will boot. However, the battery will not charge. I am getting a bright green light on the adapter. The new battery only shows 29 cycles and -1 charge on coconut battery app.
1 Comment:
Is the battery really older than that? If so, you might just have an old battery. It's been a while since Apple's been selling MacBook Pros in the 2.0 GHz range. (or for that matter, a Core Duo machine)
by
Add a comment
Add your answer
Brian Lucy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,915
