Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Questions View all
Question Closed
My keyboard right side doesn't work
I have a iMac 20° since a month my ,My keyboard Mac with wire, does not work the right side numbers, I digit the numbers but does not appear, work only the numbers of the central part of the keyboard, someone could help me?
1 Comment
Do the letters work?
by
Add a comment
Most Helpful Answer
Don't know if you have fixed this Issue.. but if you havn't..
Go into your Home Directory/Library/Preferences and find the com.apple.universalaccess.plist Put it into the Trash and Restart your Computer..
Let me know if this fixes your Issue...
Score 1
Add a comment
Please update your question with what keyboard you have, I changed it to iMac as that was the only device you mentioned specifically (and it still could be the iMac that's wrong). First, just check that you have the num lock key pressed, that's 99% of the time the problem. If that still doesn't work, try with another computer, if that doesn't work, you may want to clean it.
Add a comment
right side numbering keyboar not functioning but "+" and others work normal.only numbering from 0-9 not functioning when i prees the button.please help.
Add a comment
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,772
