Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
924 Questions View all
iPod got hot now won't turn on
I had my i pod plugged into a Harman kardon car adapter and it got really hot now it wont turn on. i am pretty handy fixing electronics but I'm not sure what needs to be replaced. will the heat affect the hard drive, screen or circuits? do you think i could get away with just replacing the battery?
thanks for any info
Add a comment
Chosen Solution
It definitely sounds like the battery fried. I just hope that's all! I'd try replacing the battery. Failing that, I'd consider cutting my losses.
I'd also get that HK adapter checked out. If a fault in the adapter caused a sustained voltage spike (I believe USB is only supposed to be 5v), that could have overloaded the battery and/or the logic board. With luck, the battery is the only problem.
Score 2
Comments:
+ agreed. Make sure that you remove the battery and replace it. Best case scenario is a new battery, worst case is bad logic board. But start with the easy part, the battery. Good Luck
by
thanks for the help
by
Add a comment
Did it get hot while in use? Or did you leave it in the car and it got hot? Sounds like something got shorted out to me.
Comments:
it got hot while in use there was a black z on the battery bar in the top corner but it shut off as soon as i unplugged it and wont turn back on that was a couple days ago.
by
Sounds like your battery is shot. Did you try plugging it into a computer?
by
i plunged it in and got nothing
by
thanks for the help
by
Add a comment
Add your answer
eric will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 2,526
