1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
mid 2012 MacBook air memory replacement
where can I find mid 2012 macbook air memory upgrade step by step instructions?
1 Comment
HI, without the proper equipment this would be pretty difficult to do. Do you own a Microscope? Hot air station? It is not impossible but I would highly reccomen getting some BGA practivce under your belt before tackling this job.
by
Add a comment
1 Answer
Most Helpful Answer
You cannot upgrade the RAM on a MacBook Air. It is soldered in place. (Src: https://everymac.com/systems/apple/macbo...)
If you have the 4 GB model, you can buy a 8GB logic board (MacBook Air 13" (Mid 2012) 1.8 GHz Logic Board) and replace it, using the step-by-step instructions at ifixit. Here is a link: MacBook Air 13" Mid 2012 Logic Board Replacement
Replace a 1.8 GHz logic board compatible with the Mid 2012 MacBook Air 13" model laptop. Includes 4 or 8 GB RAM. Fix processing issues like unexpected shutdowns, reboots or water damage. Image
Product
$95.99
Score 2
Add a comment
Add your answer
TAHIR FAYE will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 5,208
