Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Piece of plastic is broken off iPhone 3GS
A piece of plastic has broken off around the vibrate ring mute button. What type of glue/epoxy could I use to repair this?
Would JB weld work?
Also this is a precession task. I need to glue this piece back to the housing with out touching the button or having the glue drip into the phone.
thx in advance.
Score -1
Add a comment
1 Answer
Chosen Solution
i'd buy a model making glue... you know like for aircraft kits etc(airfix/tamiya? in the uk). theyre safe on plastics and have needle fine nozzle for dispensing small amounts of glue.
Score 2
1 Comment:
No JB Weld does not adhere well to plastics. You are going to want a glue that is designed for plastics similar to what polytintop has suggested.
by
Add a comment
Add your answer
Jake will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 719
