Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Questions View all
Vibrate does not work after changing battery
I ordered a replacement battery from ifixit and changed the battery following the instructions provided on the website. After changing the battery the phone no longer vibrates? I have reseated the connector for the taptic engine but still no vibration. Is there anything else I can try to fix the problem?
Score 1
2 Comments:
Does it vibrate at all? Like when you toggle the ringer switch? If I had to guess, I'd say you might've killed the taptic engine.
by
Try reseating it
by
Add a comment
When you turn the phone on how long does it take to boot up?
Does your home button work properly including Touch ID?
Does the vibrate work with the home button?
Is the charge port flex correctly seated?
Also check the front cam and earpiece for functionality.
1 Comment:
Boot up - 24 seconds
Home button works including touch id
Vibrate does not work with home button
Not sure about the charge port flex but it charges
Front cam works
Headphones work with adapter in charge port
Replaced taptic engine with new taptic engine and still does not work
Tried testing with phone open and still didnt work
All other functions work
by
Add a comment
Could try hanging a new charge port in with taptronic attached to eliminate charge port flex. If you have parts I would also try volume ribbon and front cam but it sounds board level repair.
1 Comment:
Ok thks. I guess i’ll just go buy a new phone. Seems beyond repair.
by
Add a comment
You probably damaged the small wire in the ribbon cable of the charging port or tore the haptic engine flex cable when pulling the battery. Change the charging port or Taptic Engine you’d issue.
Add a comment
Add your answer
mark giglio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 2,251
