Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Why does my iPhone wont charge after I left it drained for 2 days?
when I got a new cord, I tried to charge it but it wont...I tried connecting it to my pc it still doesn't work... what should I do?? should I replaced a new battery or should I fixed the charging pin???
Add a comment
Chosen Solution
Make sure it's not the charge cord first!
Ther 5S does not like aftermarket charge cables. Next I would change the chargeport. Could be the battery as well, but based off your description i dont think it's the battery.
Score 2
Add a comment
I agree with Andrew's answer, try a known good charging cable and wall charger first.
If that does not work then it's probably best you take it to a mobile phone shop that does micro-soldering / board level repairs for troubleshooting because this issue can be caused by many things:
- Bad Battery
- Charging Port
- Or at worst a bad charging chip which would require micro-soldering to replace it.
To do it yourself you will have to start off with trying another charging port, especially test with battery unplugged and charger plugged in, if you don't get apple logo on at this point, and with a replacement charging port assembly then the fault is most likely caused by a bad charging chip. It will cost a fair bit to buy parts just for testing.
Score 2
Add a comment
Wood tooth pick try to pick out any foreign junk out of charge port they often get a build up of dirt n dust and hair that stops charging
Add a comment
A lot of the time, iPhones that won’t charge can be fixed by taking a toothbrush (that you’ve never used before) and brushing out the port. You’d be amazed by how much lint and gunk can accumulate in there! Make sure you also try another outlet. This website has a more complete guide about what to do when an iPhone won’t charge, but although you can fix a lot of problems at home, sometimes you just need to get your iPhone repaired... or do it yourself with the help of iFixit!
Add a comment
Add your answer
Nicolle Moore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 165
