A1278, core2duo, chime:yes, white display.
Found my old macbook pro A1278 core2duo boots up with a chime but display comes up white, hard disk has been removed earlier, screen seems to be caught with funguses, i am not sure about it, is there a way to find out, that my screen is ok? With some kind of bootable usb?
Update (05/02/2018)
Update : i found out the issue and it was, the graphics chipset, Re-hot procedure worked on it, and now the macbook is blinking the folder with an question mark. but unfortunately my keyboard is kinda dead, and the hard disk cable has been lost, so my question is, will the macbook accept the hard disk caddy or bootable pendrive, directly ?
2 Comments
Double-check your components and cables, is everything inserted and plugged in correctly?
Also give it some time to boot up as it might be still loading :3
And well, you in theory could use Recovery mode to check (Just google on how to do it for your device)
by Lena Fox
everything is ok, i finally figured out the issue. :) thanks anyways.
by naineeshvrathod
