Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Questions View all
Is the electrostatic pad needed with an SSD?
When pulling the stock hard drive and replacing it with an SSD in a 2011 27" iMac, is it necessary to transfer the electrostatic pad to the SSD? I just finished my upgrade and looked down to see the silver electrostatic pad still on the old drive. Rats. I am hoping that this was needed because of possible static build up from an old-style spinning drive and isn't required with an SSD. Does anyone have any wisdom to share? I can redo the job if I have to, but I'd rather not.
Thanks,
Brian
1 Comment
Terrific, thanks!
by
Add a comment
1 Answer
Chosen Solution
Your fine ;-}
Even if you put the foam pad on it wouldn't help as the distance is greater height wise.
Score 3
Add a comment
Add your answer
Brian Irwin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 6
All Time: 110
