Repair and disassembly guides and support for dish washing appliances.
707 Questions View all
Dishwasher spray arms not spining
I have a GE dishwasher/ top and middle arms don't rotate/what is the 3/16 hole at the point of connection of the vertical pipe and the horizontal pipe that goes to the middle sprayer. The hole continues thru the back wall ofthe washer.Is this for a screw to hold the pipe(conduit) to the back wall or for some other reason having to do with the non rotating sprayers
Score 1
1 Comment:
What is your model number?
by
Add a comment
1 Answer
Depending on the model, you might need a seal at the bottom (inside) the dishwasher, there is a horizontal tube that feeds the tube along the back of the dishwasher, which feed the two top spinners,
Check this connection at the center bottom of the dishwasher.
Add a comment
Add your answer
kendonius will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 107
