Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
471 Questions View all
Laptop shuts down when disconnected from power at 60%
My mbp suddenly started shutting down around 51 to 61% battery when it is not connected to the power cord. The battery status shows that I need to service the battery, but it is no longer under warranty.
I've downloaded Coconut Battery to see my battery's condition, but I'm unsure what to make of it. I've downloaded Python Launder to run an application at log-in, but I get an error on the code I found online. The computer runs well when it's connected but I'm hoping to find a fix because I can't have it conneced all the time.
I've tried doing an SMC reset, but that did not fix the problem either. Any help would be greatly appreciated!!
Score 1
Add a comment
Chosen Solution
@bobneedshelp
Design Capacity is listed by Coconut battery at 18.9%. For something from 2014, it should be in at least the 80%s. This is indicative of a failed battery.
If you fix it yourself, it is $50-$60 for the battery. Please note, that some disassembly is required, and the battery is glued down to the underside of the palm rest.
Here is the teardown guide if you need it.
MacBook Pro 13" Retina Display Mid 2014 Repair
MacBook Pro 13" Retina Display Mid 2014 Battery Replacement
Score 3
Add a comment
I believe you have a bad battery. You could try sending it to Apple or buying a new one online or in stores, but other than that I’m not sure how to help.
Add a comment
Add your answer
Bob Ray Delgago will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 117
