Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36474 Questions View all
Possible to do recovery without installing baseband?
Hi Community,
I am wondering if its possible to customise firmware to remove the baseband installation process.
I currently have an iphone 7 which is just going to end up becoming a data recovery due to GOD knows what the last repair shop did. However, i can nearly install firmware up until the dreaded 80% install, -1 baseband error (using 3U with data being saved option ticked)
I have done all repairs around this error and cant invest anymore time on the project, but just wondered if this is at all possible??
Thoughts and advice?
Score 1
Add a comment
1 Answer
Most Helpful Answer
on 3u did you try unticking reserve baseband while flashing under the pro flash section
Score 2
5 Comments:
Yep. Still fails at that point
by
what about removing the baseband ic itself, the phone will boot without it
by
It boots to recovery mode, but I can still flash while keeping data. If I remove the baseband, won’t it still fail in the recovery process??
by
Did you ever got to solve this?
by
I hope he attempted exit recovery mode on 3utools becaused failed restore / update attempts keep a phone stuck in recovery mode.
by
Add a comment
Add your answer
Jacob Harvey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 17
All Time: 4,177
