A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
569 Questions View all
PS4 disc drive only takes discs in so far
I had trouble with the rollers not taking discs in, because the middle piece had come loose. I have successfully fit it back in, but now discs only get around 3/4 of the way in before they get stuck, after the rollers have fed the disc towards the magnet.
When I took the disc drive out to reattach the roller, I also found a mystery piece that was loose; I’m guessing it may have something to do with it? It’s a thin black shoulder joint that has P1 written on it. I’d attach a photo but I can’t seem to on my iPad.
Any ideas?
Add a comment
1 Answer
What is this mystery piece I found inside a PS4's optical drive?
this should address where the mystery piece goes, as far as the disc drive still being sluggish and not fully taking discs in here’s my own experience:
I just had this issue on a PS4 Slim, turned out to be dirt jamming up the grooves in the disc roller gears, it was causing the rollers to be sluggish and skip a little but ultimately didn’t have the torque to fully pull the disc in or eject it once forced in, this would also prevent the disc from settling all the way in so that the drive could properly read it. Once I cleaned out the gear connected to the rollers and carefully used a small jewelers flathead screwdriver and a nylon brush to clean the other two gears it works like new. Hope this helps others with this issue.
Add a comment
Add your answer
Joe Neave will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 248
