Cannot update to High Sierra
I just replaced the logic board and i could only install OS 10.8.5
High sierra is refusing to install. Is it due to firmware issue. What should i do
If you replaced logic board you probably need set up correct date:
https://bensmann.no/changing-system-date...
after should be everything OK.
Thanks, It is already showing the correct time and date
Can you give us the exact error message, that might give as a better clue here.
Also have you tried running Disk Utilities First Aid function to check your drive.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 55
