Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
iPhone 6 Poor Wi-Fi Connection
My iPhone 6 started having a really poor Wi-Fi range. I have to be close to router to connect, and it sometimes disconnects when standing just next to the router. And the connection is really slow.
It reconnects after a few minutes.
Some say I should change the antenna, some say I should only change the flex cable.
What should I change?
Thanks!
Add a comment
Most Helpful Answer
The front camera and ear speaker share the same flex, so it's normal that both could fail at the same time. The WiFi antenna is in the same area but not physically part of the same flex. It's actually in the housing instead of embedded within the screen assembly. Did something happen to the phone recently, such as a heavy drop, a repair or contact with water? Those are the kinds of events that could cause multiple problems.
Score 2
Add a comment
There is an inter connected antenna on the underside of the board that may need to be reseated. Unless you are extremely diligent with the screw and all of the small parts I would suggest getting some help with the repair.
If this doesn’t solve the issue there is also microsoldering options but we can cross the bridge on that after the antenna is checked.
2 Comments:
You mean to reseat the antenna. Not replace it? Can you please refer me to the guide.
by
here: iPhone 6 Wi-Fi Antenna Replacement it says replacement, but you can use this guide to get to the part.
by
Add a comment
Like Scott says replacing the wifi antenna is your first option ,it's common for this part to fail and cause weak wifi.
Add a comment
Add your answer
AaAa will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 6
All Time: 246
