Second generation desktop trackpad released by Apple on October 14, 2015. Model A1535.
Does Magic Trackpad 2's battery connector same with iPhone 5?
The battery connector seems to be same with iPhone 5.
Can I replace Magic Trackpad 2's battery by iPhone 5's battery for temporary?
Score 2
3 Comments
Thank you all for detailed answer.
Since I can't find trackpad 2 in Mac and there is no response when I connect my trackpad 2 to Mac by lighting cable, I suppose if it is possible replaceing the battery to make sure what problem it is.
Maybe I have to buy the right battery first.
by
Sang that sounds like a very good first stop. That way you know for sure if it is a battery issue or not. Best of luck to you.
by
I replaced the right battery, but it didn't work at all. Certainly I checked the voltage of the new battery upto 4.1V, while the old one is 0V.
by
Add a comment
Chosen Solution
Sang no you cannot. Different battery (we all know how finicky Apple devices are when it comes to batteries) and a different connector etc. Buy the right battery so you do not have to connect anything temporarily and avoid making costly mods and/errors.
Score 1
Add a comment
Most Helpful Answer
Although it MAY be possible, for your own safety and devices I highly reccomend NOT doing this.
Score 1
Add a comment
-> Magic Trackpad 2 Teardown
It seems that you can do it , but the battery will not have the same capacity (battery drop quickly).
There is very similar but not the same voltage. (drain battery also more quickly)
Also check it might require to change the connectors to install it,
might need soldering skills for that .... I don't recommend to do it for long last solution...
Add a comment
Add your answer
Sang will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 1,110
