Released in 1999, successor to the original PowerMac G3, 300-450 MHz, 64 or 128 MB of RAM, 6 or 12 GB HDD
Black Screen with Backtrace and Exceptions
Running OS X 10.4.11 on PowerMac G3. The system is constantly freezing and I have to restart. Often I get a black screen with a long list of backtrace and exceptions.
There is an extremely long stream of info on a black screen. Below I've listed one portion which differs from the rest:
Backtrace:
0x04DF358C
Kernel loadable modules in backtrace (with dependencies)
com.apple.driver.ndrv.ATY.Rage128.0x4df009c(1.0.2f 47)00x4def000
Exception state (sv=0x1D20C780)
PC=0x000AF354; MSR=000081030; DAR=0E02FD000; DSISR=0x42000000; LB=0x000AC134; RI=0x0000B9E0;XCP=0x0000001C (0x700 - Program)
Can anybody help me fix this?
Score -1
1 Comment
How much RAM do you have?
by
Add a comment
1 Answer
Chosen Solution
what you're getting is called a kernel panic. start up from your system installation disk, go to the second screen pull down menu to utilities > disk utility and select your drive on the left. run the repair till it runs clear. if this fails, reinstall your system. how much ram do you have?
Score 2
3 Comments:
I've only got 288 MB of memory. I've avoided investing too much into the system since it has this problem. If I could just get it to stop freezing up, I might have a chance to get to know and love it. Then I might consider upgrading it.
by
I don't have the original system disk that came with the system. I only have the OS X 10.4 installation disks.
by
You're running on the minimum amount of RAM. Use the 10.4 disk for repairing the drive.
by
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 651
