Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Screen getting vertical and horizontal lines over time
Hey y'all! So the problem is with my 5S is the screen. If i unlock the phone, then leave the screen on for too long (depends on brightness) the screen gets glitchy, and the multitouch glitches out, then stops completely.
This is the how it look when its almost completely glitched
if i leave the screen on the dimmest brightness setting, it takes about 10 mins to get some lines (still working, just a bit odd looking), but on max brightness, it takes about 3 seconds for the screen to glitch out completely.
The screen itself is not damaged, i may have dropped it, but not the day before the problem occured.
Anyone can help what can cause the problem?
Thanks in advance!
Add a comment
1 Answer
Chosen Solution
The first thing to try is to replace the screen assembly. That will tell you if the problem is with the screen or with the logic board. Because you say you haven't dropped the phone, then it's probably not connector related.
You can try this yourself by following this guide.
Score 3
Add a comment
Add your answer
Hans The Kid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 181
