Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
What went wrong? Just added the SSD using the dual drive kit
The guide is great, but after installing the SSD and re-assembling my iMac, it doesn’t start.
I press the power button but it’s dead, like when power cable is not connected. I’ve opened it again, but every cable is on it’s correct place. Could someone help me??
2 Comments
I will answer on friday when I'll be back home. Excuse me, and thak you a lot for your answer! You are great!!
by
Hope you're having fun at the slopes ;-}
by
Add a comment
1 Answer
Most Helpful Answer
What does the onboard diagnostic LED's telling you? Make sure you've got all the cables plugged in (display removed) locate the LED's underneath the audio cable (carefully pushed aside). Try a second power cord if the LED's aren't lit.
Here's the LED's under the cable
Score 1
Add a comment
Add your answer
Elija M will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 39
