The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
PS3 Fat 80GB 2USB port model issues
Hello,
My ps3 has one of the most odd symptoms I have ever experienced.
Things to note (the ps3 did have YLOD when I purchased it)
I fixed this issue and the system runs very cool. I took all the dust out of the console and dusted the board off myself.
Here is the issue.
Upon initial boot up the system will load a game and then go into that game’s menu, however right after loading the save file for that game(sometimes directly sometimes minutes later ) the system will crash and give the YLOD and then blinking red light(overheat).
That being said the system isn’t remotely warm at this point. Plus if you flip the switch in the back of the console off and back on and then reboot the console and let it do its (hard drive checkup) it will run fine for hours without a single hiccup.
My main question is
Do you think this is a HDD issue?
Do you think the issue is stemming from the original YLOD.
Any and all help that is relevant is much appreciated!
Add a comment
1 Answer
The yellow light of death can indicate a power-supply or faulty Chips on the board. you said you removed the dust etc, did your reflow the board ? without reflowing the board the device will still be faulty. the damage is caused when the device gets hot and the solder joints melt or crack through the hot cold stages.
Cleaning the device out at this point is not a fix as the damage is already done to the chip. The fact it is when you are in a game or loading a save could relate to this problem the ps3 menu is requires very little power hence why the machine maybe stable at this point however as soon as your game loads your putting strain on the cpu and the GPU which if they are damage would cause instabilities
PSU faults are also shown by a YLOD although this usally happens when the machine wont turn on at all.
Hope this helps
1 Comment:
thank you for the response. However I have reflowed the board myself. The system will work for hours maybe even days on end if you do the above process I mentioned that is why I’m honestly baffled . If it was a more common thing even while playing games then the YLOD or Overheat issue would make sense .
It’s only on that initial boot up that it has this issue.
by
Add a comment
Add your answer
Jesse Warren will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 578
