Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Why is my iPhone 5S not pass the apple screen?
I bought an iPhone 5S to fix, the problem is that it does not load iOS.
If I connect to the charger it shows the apple logo and darkens the screen next.
The battery seemed stale so I removed it, at that time it is only powered by the USB cable, which is not original.
I think this was caused by an update that did not finish, the battery may have run out midway through the process.
The problem is that linux, nor itunes in virtualbox recognizes it.
I did the procedure to put into recovery but I do not know if it works if the iphone does not have a battery.
Tell me if I can put it into recovery mode without battery or not.
Add a comment
Chosen Solution
A battery needs to be installed to turn on an iPhone properly, do a restore or update on the phone.
Score 3
Add a comment
In most cases, you can solve these problems by putting the phone into recovery mode and restoring it from backup. To do that, follow these instructions:
1. Connect the iPhone's USB cable to your computer, but not your iPhone.
2. Turn your iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
3. Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
4. When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
5. You'll know the phone is now in recovery mode because a window in iTunes will tell you.
6. You can then start the restore process by clicking the "Restore" button in the iTunes window.
1 Comment:
@adamp1324 not without a (new) battery.
by
Add a comment
Add your answer
Rafael Cout will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 49
