Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Error -36 when trying to copy files from SSD
When trying to transfer files from SSD to USB key, i keep getting error -36.
Something with corrupted sectors on the SSD.
1. I tried doing a dot_clean from terminal on the folder i wish to copy and on the USB key.
2. tried booting up with Command-R, OS X recovery, to do a repair of the SSD.
Sill no luck. Still error -36
Anything else i can try, or is the SSD "ruined"?
Best
Add a comment
1 Answer
Most Helpful Answer
I am assuming that
a) you have a non-apple SSD, and you have updated to the latest firmware for the SSD
b) you've run disk utility
c) you have checked the USB key for errors or tried another USB key?
On an SSD, if the file you are trying to copy is corrupted, then it is toast.
However you can try in terminal a 'cp -Rfv <source> <destionation>' so that it forces a copy of the file with errors and all.
Score 2
4 Comments:
Likely has a M.2 SSD with an adapter ;-{
by
The SSD is the original from the MBA.
I ran disk utility doing a repair, but no luck.
Tested with different USB keys.
I will try the 'cp -Rfv <source> <destionation>', thanks!
by
It maybe time for a new SSD drive I would strongly recommend sticking with either another Apple SSD or if you want something larger go with either OWC or Transcend both offer good replacement SSD's for your system.
by
Add a comment
Add your answer
Anders Laursen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 145
