Error!please plug out charger
Unfortunately system UI has stopped
Usually either the data on the system UI app needs to be wiped, firmware reflashed on phone again or factory reset via recovery menu which will wipe wipe all data on your phone.
No this most be from your charging port try to repair your charge port it it's isn't change the problem the check your phone battery connection or change new battery
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 4,036
1 Comment
I changed the charging port, changed the charging board and even changed the battery, it was still saying error please plug out
by Takeover Academy TV
