The Honor 3C is an Android smartphone produced by Huawei and released in December 2013 for 3G, April 2014 for 4G, and August 2014 for 3C Play. The Honor 3C can be identified by model numbers H30-T00 and H30-U10.
33 Questions View all
Error!please plug out charger
Unfortunately system UI has stopped
Score 1
1 Comment
I changed the charging port, changed the charging board and even changed the battery, it was still saying error please plug out
by
Add a comment
Most Helpful Answer
Usually either the data on the system UI app needs to be wiped, firmware reflashed on phone again or factory reset via recovery menu which will wipe wipe all data on your phone.
Score 2
Add a comment
No this most be from your charging port try to repair your charge port it it's isn't change the problem the check your phone battery connection or change new battery
Add a comment
Add your answer
Sridhar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 4,036
