shuts down randomly, switching beetween charging/not charging
Hi!
My MBP shuts down after a few minutes if it is not plugged in, so I think my battery is defective.
But if I plug it in and let it charge for a while and it is nearly fully charged then it switches between charging and not charging and the LED on the MagSafe is switching (green - orange) too.
Is this the power adapter or the Left I/O Board or is this the battery too?
If I take out the battery it is still running.
Can I check the parts somehow?
Thanks for your help!
StonerL
Score -1
Add a comment
1 Answer
Most Helpful Answer
a defective battery can cause the symptoms you are experiencing. Since the unit runs fine with the battery removed, the power adapter and laptop power circuitry are probably fine.
There was a recall on certain MacBook Pro batteries - more information can be found here:
http://apcmag.com/macbook_pro_battery_re...
The exchange program has been closed for over a year, but the battery identification info might be useful to you.
Score 1
3 Comments:
Thanks for your answer!
I bought a new battery a year ago because my old was defective too, but I came to late and so it was not replaced by apple.
And you think if I buy a new battery the problems are gone?
StonerL
by
How long/if Apple honors defective batteries is often up to the "Genius" you have help you.
Look for battery bulge - a safety issue - you may have better luck getting a replacement covered.
Good Luck,
N.
by
it is very possible the replacement battery was part of the defective batch - if you have the receipt, see if you can talk Apple into replacing it. As machead stated, if you can go into an Apple Store you have a very good chance of getting it taken care of anyways.
by
Add a comment
Add your answer
StonerL will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 3,446
