Why is my freezer leaking water into the fridge
Why is my freezer leaking water into the fridge?
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,258
2 Comments
Make and model please
by mayer
kenmore elite
by debra downs
