My screen is grey
My screen is grey!!!
if your screen is grey, as in monochromatic, you can fix that by changing the settings in the subpanel "Screen accommodations
you can get there by following the steps as follows; Settings, General, Accessibility, Screen Accomodations
if your screen is a blank panel of grey, you may very well have an image failure.
in which case, it could be a couple things.
Most likely, this will require a screen replacement, however there are other things it could be. a GPU failure in the board, a disconnect in the LCD connectors, a damaged LCD connector, or least likely of all, a software failure.
It’s a grey block but it’s not in all screen. Is it display accommodations ? But there are many options in it
if only part of it is grey, then its not a setting.
So what do I do?
move to the next step. try a screen replacement.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
