The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1186 Questions View all
Coffee fell on power button area, liquid damage?
Yesterday, I accidentally fell my little coffee on my MacBook pro button area. I clean up right away. the computer is shut down. Make sure there is no liquid inside. Then, my MacBook still able to use. I did the wrong thing here. I should wait, not using my MacBook after it.
Today, I found that my battery is not working. I have to connect my power source to use my MacBook. When it is connect to power, the light is orange on my power adapter. Battery condition is replace Now. I can use, not harm to my computer.
Today, I went to the apple store for repair. They test my mac. All unit test pass but battery fail. So, they going to replace my MacBook's battery. Since I bought the apple care for my mac. They do not charge me but they say there will be the charge if it is liquid.
So, how much will they charge? Will battery damage because of the coffee? Is it worth to replace the battery? Or is there any cheaper way to fix it?
I bought my MacBook in 2015.
1 Comment
depending on how much coffee was spilt it may have been a coincidence that your battery failed at the same time Id let apple repair it and see if they come back with water damage or not.
by
Add a comment
1 Answer
Chosen Solution
Water damage can ruin a perfect day.
water damage may or may not make immediate effects. but eventually the device will die due to that spill years ago.
you need to fully disassemble the laptop: MacBook Pro 13" Retina Display Early 2015 Upper Case Replacement (this guide will remove all parts)
and clean it using this wikis directions: Electronics Water Damage
whether or not the battery fails, replace the battery Lithium batteries can explode or catch when in contact with water.
MacBook Pro 13" Retina Display Early 2015 Battery Replacement
MacBook Pro 13" Retina (Early 2015) Battery
MacBook Pro 13" Retina (Early 2015) Battery Image
Product
$79.99
MacBook Pro 13" Retina Display Early 2015 Battery Image
Guide
Difficulty:
Difficult
45 minutes - 2 hours
MacBook Pro 13" Retina Display Early 2015 Upper Case Image
Guide
Difficulty:
Difficult
3 hours
Add a comment
Add your answer
Xingsong Lin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 756
