Repair manuals and support for 4-wheeled passenger and cargo vehicles.
11900 Questions View all
Question Closed
car stalls out when starting, but ok in gear
stalling at start up
2 Comments
Irma, if you need some help with this we all will be very glad to do so, but we do need more information. Like what car, what engine, what happened, what exactly is it doing etc...
by
does it stall whilst sitting in park ? but not while driving ?
by
Add a comment
Most Helpful Answer
Hard to tell with all the sensors in newer vehicles, and without knowing more about your specific model and the problem............ my jeep needs a new idle control sensor/valve, i may have the exact name wrong. (sensor in the throttle body) So it will not idle even in gear, I cleaned the sensor and the throttle body and it works "ok" for now until i can get the new sensor. Anyway it could have been a few things and I would not have known the exact problem without taking it in for service and having a skilled mechanic run a diagnostic machine on it.
Hondas at least quite some time ago when i had one, idle high when started cold.
Take it in for service, all repair shops have or should have a computer that will read codes if any, or tell the cars computer to adjust the idle and do other things to help figure out what the problem is. This kind of diagnostic is usually not very expensive, $25 or so and does not take very long......
Score 1
Add a comment
Keith
When you start the car you have to put it in gear right away, then you can put it in park again and it is fine.
1 Comment:
the car is a mercury,topaz year 1993, v6
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 661
