Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Questions View all
Broken LCD. MacBook Pro 2017 mid. EMC 3163. Whole logicboard?
Hi IFixit,
Do I need to remove the whole logicboard to access the components necessary to replace the LCD on a mid-2017 MacBook Pro Touch?
Or will I be able to do the replacement simply attaching a few cables and screws to the bottom exposed logicboard if I buy an LCD assembly for the machine?
Thank you.
Sincerely, A tech repair person
Add a comment
1 Answer
Most Helpful Answer
The display can be removed from the chassis from the bottom. I've marked the cables in blue and the hinges pink
Score 1
2 Comments:
The section in light blue does not indicate how to get the secondary cables out from under the logicboard. Do I need to remove the entire logicboard to get access to that section when replacing the LCD? I bought a replacement LCD and there is a section of ribbons on two springs. I can't seem to get underneath it. It seems I have to unscrew all the screws by the fans, and logicboard screws just to lift the board and remove those ribbons from the old LCD. Am I missing something quicker?
by
I did remove the logic board. But I don't think it was needed, the ribbon cables connect to the bar (2 screws) and when you pull the display off the bar will be loose with the display.
by
Add a comment
Add your answer
Abraham will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 262
