In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423 Questions View all
How to remove a dent from the screen's back aluminium case?
My macbook air 13 inch felt from my lap, and the aluminium case at the back of the screen has now a dent on the corner.
Do you know how to remove the dent? Do I need to disassembly completely?
1 Comment
Do you have AppleCare + ?
If you do Apple will replace the display assembly for a fixed cost which is still cheaper than getting a new display your self and putting it on.
by
Add a comment
Most Helpful Answer
Sadly, The design of the lid is not designed to be that serviceable! Here's an older display to give you an idea how yours is constructed: MacBook Pro Retina Display Teardown.
Best to just replace the complete display assembly: MacBook Air 13" Early 2015 Display Assembly Replacement
MacBook Pro 15" Retina Display Mid 2012 Image
Guide
Difficulty:
Moderate
MacBook Air 13" Early 2015 Display Assembly Image
Guide
Difficulty:
Moderate
45 minutes - 2 hours
Score 1
Add a comment
I would not bother. Unless you have serious stoved in the corners or cracked the screen. It is easy to brake other components if you are not experienced repairer. I would put a sticker over it or get a vinyl wrap.
If you have don't have applecare but have full contents insurance on house you might be covered for electronic goods incidental damage.
Add a comment
Add your answer
Max Echeverria will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,990
