Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Why is there a difference between apples 11.3 beta report of battery.
I recently replaced the battery in my iPhone 6 s plus. Thank you Ifixit. CPUdasher x reports the battery is fine, but iOS 11.3 beta 2 reports it needs to be replaced at 64% of capacity. Do you know why this discrepancy? The battery is only about a month old. Thanx, roncbee
Add a comment
1 Answer
Chosen Solution
did you calibrate it? at the bottom of the battery replacement guide it says:
"To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%."
iPhone 6s Plus Battery Replacement
Score 1
3 Comments:
Yes, I did. I just installed the latest beta, 2 , of 11.3 with the battery report built in. It reports the new battery is only at 64% of its capacity. The battery apps from the store show the battery to be at 100% of capacity. Why the broad discrepancy?
by
I'm not sure. If its the ifixit battery I recommend you contact support. http://help.ifixit.com/
by
I don't know what CPU dash X is, but these are the methods I use to check battery health.
Use either one of these methods to check your battery:
Windows PC - 3UTools
Mac OS X - CoconutBattery
Using mobile app - Battery Life
by
Add a comment
Add your answer
Ronald Branscome will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 171
