Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
My GPS Antenna is not working, and I cant find a DIY fix.
I have an iPhone 6 that is having cellular antenna issues. Everything I look into is how to replace the wifi antenna and that is not what I am trying to do. Does anyone know a way to fix this? The phone will not connect to GPS and the Fit bit I got my sister for Christmas will not connect to the phone because of it. HELP!
Add a comment
1 Answer
Most Helpful Answer
"Weak or lost wireless connections
You have trouble connecting to a wireless network.
Dirty antenna grounds
If your iPhone has been disassembled before, it's possible that finger oils were left on the grounding locations for the Wi-Fi or Bluetooth antennas. These oils will cause grounding issues for the antennas, which could lead to a weak signal or no connectivity at all. Be sure to clean all grounding points with an electronics cleaning solution before reassembling your iPhone to prevent grounding issues." iPhone 6 Troubleshooting
iPhone 6 Antenna Flex Cable Replacement
Score 1
Add a comment
Add your answer
leftymckee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 938
