Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
Put in a 3rd party battery, no longer charges?
My original apple battery swelled and stopped working. I replaced it with a 3rd party battery I bought off ifixit. Immediately though the battery stopped taking a charge and I had difficulty getting the laptop to turn on even when the power cord is connected. From my limited reading this may be an issue with the logic board and 3rd party batteries? Do i need to replace the logic board now as well as the battery? Can I just get a new battery?
Score 1
3 Comments
Lets first check things download this app CoconutBattery then take a snapshot of the main window so we can see what its telling us. Also give us a snap of the battery data.
Adding images to an existing question
by
No battery info is displayed.
by
I just put in a brand new iFixit battery, too. 1 cycle, 100 days old. Coconut shows all of the battery info, menu bar shows the battery logo with the lightning bolt but battery is not charging. MBP will only fire up when connected to power. Swapped back to original battery (over 650 cycles). Boots, charges no problem. Is there some sort of software/hardware that prevents 3rd party batteries? It seems not everyone has this problem. (FYI: was on Catalina, downgraded to Mojave, same symptoms)
by
Add a comment
Most Helpful Answer
If thats the case you should have a crossed out battery in the menu bar.
That would imply SMC has a major failure. Did you get your system wet somehow? Can you give us some background on what happened.
I'm wondering if the battery swelled up because of the liquid damage or if the battery somehow damaged the logic board. Basically, which came first the horse or the cart ;-}
Score 1
Add a comment
Option one: Get new battery.
Option 2: Try different charger.
Option 3: Get the charging panel replaced.
Add a comment
Add your answer
jonny360 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 314
