Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Screen goes dark during phone calls after replacement. Help!
iPhone 6s plus, I replace a cracked screen by purchasing the aftermarket kit from ifixit. The repair went without a hitch since I was following the disassembly guide. The replacement screen displays the correct colors and is perfect.
However, during calls, the screen goes dark as if the sensor on the very top of the screen is being blocked. Did I do something wrong or is my replacement unit the issue?
Score 1
Add a comment
Chosen Solution
You may have damaged or incorrectly installed the Front Camera/Sensor flex, which contains the proximity sensor. You should go back through this guide to double check your work.
Score 3
Add a comment
Have either of you installed a screen protector or left the plastic protection on that came with the new screen? If so try removing it.
1 Comment:
There is no screen protector on it and t he plastic protection has been removed.
by
Add a comment
Add your answer
Riannon Webb will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 5
All Time: 90
