The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
Why doesn't my controller stay charged?
I purchased my PS4 about a month ago, its until now that my controller somehow dies very easily. I have it plugged to the console with the included cable and charges and shows that it's charging. Works fine plugged in but then after like a hour being plugged in, it dies when i disconnect the controller from the console. is it a battery issue? or is the charging port faulty? HELP!
Add a comment
1 Answer
Your problem could be one of three things:
1) The cable you're using may be faulty. Try a different cable and see if that helps.
2) The battery inside the controller may be faulty as well. However, they're easily replaceable.
And the worst situation would be:
3) The USB port on the controller is indeed bad. You may need to get another controller and/or have your current one sent back to Sony for replacement under warranty (if it hasn't expired).
I would try 1) first and see if it helps. If you go with solution 2), you may void the controller's warranty and you'll have to solve 3) by purchasing another one.
Add a comment
Add your answer
Richie Tzib will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 172
