Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Home Button Nowhere to connect to
So my Moms iPhone 6 had the problem that the Home Button sometimes didnt register when being pressed to finally to work anymore.
I ordered a new Home Button off Amazon and tried to replace it today, when i wanted to disconnect the old Home button from the flex cable i quickly realized that there was nowhere to connect the new one, i thought that i may ripped off the connector but that was also not the case.
Pictures : https://imgur.com/a/Ex6oz
Would i now need to also order a new Home Button Flex cable and replace that ?
Add a comment
1 Answer
Chosen Solution
Its ripped.. the connectors on the flex are probably stuck in your mothers homebutton. You’ll need a new backplate.
iPhone 6 LCD Shield Plate with Sticker and Home Cable
iPhone 6 LCD Shield Plate with Sticker and Home Cable Image
Product
Score 1
2 Comments:
okay thanks for your help, is it also possible to just buy the flex cable and go with this tutorial : iPhone 6 Home Button Cable Replacement
or does the Sticker not stick as good anymore after opening it up ?
by
You could just order the flex cable, but I personally only orders the complete thing.
by
Add a comment
Add your answer
KekoMaster Atmisbir 2 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 64
