1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
Recovery Drive no matter what I do.
no matter what startup key combos I press it will only go to recovery drive. Disk Utilities says SSD is fine, but when I connect to the internet and try to install from there, it verifies then says error preparing disk. And it also tries to say my install high sierra is damaged and can't be installed.
Again
2 Comments
Did you just buy this system used?
by
Yeah, so I'm just trying to figure it out. I'm self taught on pc in general. single user mode is the only key combo that works. I was hoping to just type some commands in there to get it back on track. any help would be appreciated.
by
Add a comment
1 Answer
Chosen Solution
First Apple has a date test within the OS installers so you do need to make sure the date is correctly set manually or via the internet time server (Hint older versions of OS will need the system back dated to their release window).
Update (01/27/2018)
Sadly, your system was likely stolen so when the installer runs it won't install the OS.
Best thing to do here is to return it to the seller so they can remove it from their Apple ID or just get your money back.
Score 1
4 Comments:
I'm trying to set the time & date. on pc you enter bios and do all that. except for "single user mode"it will only go into recovery mode. is there a way to change the time in single user mode? or if I posted the boot log could you tell me where the problem is?
by
In safe mode you still can get into the preferences which is where the Date & Time setting. I don't think thats you issue.
You'll need to export it to a PDF then follow this guide: Adding images to an existing question.
by
There's nothing showing in the log that explains your issue.
by
Hey Dan, OMG your not going to believe what it was. The LEFT OPTION key doesn't work, lol. Thanks for all your input and help.
by
Add a comment
Add your answer
Paul Perez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 57
