A collection of guides and support to help with washer repair.
Washing Machine Suddenly Stop on Wash Cycle?
Hi,
I need some help my washing machine has stopped working. What happens is i set the temperature and the machine spins a couple of times before it suddenly stops? It doesn't lose power or anything it just completely stops after a few spins on the wash cycle. Any ideas what it could be? It's an indesit washing machine and it's pretty old.
Thanks
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Score 1
Add a comment
Add your answer
Bhavick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,358
