A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 Questions View all
l.f. lights up, pressure is 40 faucets on,no kinks, can hear water flo
l.f. alert comes on. i have checked the hoses and the screens and can hear the water flowing when i start the cycle.my water pressure is 37 as i am on a well. after 5 min. or so the long flow indicator lights up. what else could it be?
Add a comment
1 Answer
Most Helpful Answer
he Error code LF stands for 'Long Fill'.
If the water filling time exceeds ten minutes, it means the water valves have turned off. LF flashes when the water level does not change for a period of time on or water is present but control does not detect the water level changing.
To deal with this, check the hose from the dispenser to the drum to make sure the water flows through. If not, you most likely have a faulty water inlet valve assembly.
Score 1
Add a comment
Add your answer
Neil Thomsen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 59
