Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Battery safe to use?
About a month ago, I took out a brand new battery from an iPhone 5s I was fixing. Upon the removal of the battery, I couldn't ignore the fact that I had bent the battery ever so slightly. On that note, I then proceeded to push the slightly bent corner back into place as best as possible. The battery still works, but I was curious if the battery is still safe or even recommended to continue using. I will provide pictures.
Add a comment
1 Answer
Chosen Solution
Hello,
no I it's not recommended to use this battery. And it isn't safe to battery is dangerous if damaged. Also now iPhone batteries are cheap. Link below.
iPhone 5s Replacement Battery
iPhone 5s Battery
Replace a 1558 mAh battery compatible with iPhone 5s.
5.92 Watt Hours (Wh), 3.8 Volts (V). Compatible with all iPhone 5s models. Image
Product
iPhone 5s Battery
$29.99
Score 1
Add a comment
Add your answer
Erick Villa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 216
