Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1696 Questions View all
Frigidaire FFET1022QS does not cool properly
Frigidaire upright fridge FFET1022QS compressor runs on and off, seems okay? However, when I adjust the cold settings for both fridge and freezer, the fridge unit does not cool properly! The freezer does not freeze items, the items are cold, but not frozen, even if I adjust the dial in the freezer to max cold!
The fridge area is colder than the room temperature, but when I set the electronic setting to #4 or even to #5 (1-5 setting only, 5 is coldest), after about 20 minutes the setting returns to #3 and stays there, it will not stay at the setting I choose for the fridge area. (LED lights for setting point at each number 1-5).
The freezer seems to be colder than the fridge area.
I'm at a loss on this one, please help!
James
Add a comment
1 Answer
Have you took a look at this? Why is my G E refrigerator cool but not cold?
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 502
