2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Discrete GPU not showing in System Report, what to look for
Just recently I discovered that I wasn't getting the GPU features I expected from my Macbook. After some investigation I discovered that the System Report is only showing the integrated Intel 4000 HD graphics, not the nVidia GT650M discrete GPU that came with the original system. I've also tried gfxCard status which shows only the Intel graphics. Oddly, when I try to switch to "integrated only" I'm not able to because Google Chrome Helper requires the discrete GPU (which, as you may recall, doesn't exist as far as OS X is concerned).
Additionally, for the last several months when rebooting it can take up to several hours before I'm able to actually log in. During that period the screen is completely black, although there are startup chimes. There are no errors I can find in the system logs and EtreCheck is not reporting anything other than com.adobe.ARMDCHelper.* (which seems unrelated).
It's as if the nVidia GPU was never there and never meant to be there. I have no idea how long it hasn't been working since there are no errors to indicate it isn't present and I'm not in the habit of periodically checking my system report just in case some of my hardware has disappeared. Could the "missing" GPU be related to the restart problems?
Is this something that might be fixed by resoldering? Or is it more likely the chip itself has failed due to thermal stress? Is there any way to tell? Any other possible cause?
Apple wants $566 to replace the logic board (my machine is "not one of the affected machines" a determination made by, I'm guessing, dowsing since they were not able to actual run any diagnostics) which really isn't all that bad, but when you add in the dodgy battery ( "Service Battery", 914 cycles -- which honestly seems a bit low for a machine that's been used daily for 5 years) and needing a larger SSD, we're starting to approach new machine territory. Spending $2-300 for a fix though seems reasonable -- more for the ability to reliably restart (so I can confidently apply system updates) than for unlocking greater GPU power -- if I have a reasonable expectation that it will help.
Thanks for any tips.
2 Comments:
So System Report under Graphics/Displays only lists the Intel graphics 4000 entry and not the Nvidia GT650M as well. How odd...
Do you run heavy graphical stuff on your system?
by
I am starting to do some Unity development now, and that's when I discovered that I didn't have certain features available (specifically compute shaders). It's not a deal-breaker, but combined with the reboot issue I started to wonder if the 2 might be related.
At least if I was using Windows I'd probably get a blue screen to let me know something was amiss with the hardware :)
by
Add a comment
1 Answer
While that appears to be a lot of money Apple will honor the price and also replace the battery as well (Apple Store or Apple mail-in). I would look at the newer systems first to see what they will cost you and then decide if the price is worth it.
Don't forget your peripherals (USB-A and/or Thunderbolt2), you'll likely end up needing dongles or external connection hub for them.
I prefer the MagSafe power connection. I've had at least six systems come in with damaged screens and dented/damaged bodies from people snagging the cord pulling the system to the floor with the newer USB-C power connection.
While the new systems have some nice points I'm not sure their failings make it worth jumping yet. You'll need to be the judge based on what your needs are.
2 Comments:
With a houseful of cats and children I definitely appreciate the MagSafe... although it didn't save the power cord from kitten teeth.
Regardless of any new features and/or failings of the new machines, it just really bugs me that I've got a perfectly serviceable computer that, at least for my workloads, is performing as well as a 2017 Dell Windows machine that I use for my day job, and the expectation is that it just gets trashed and replaced with new hardware.
by
I'm hoping Apple got the message the new MacBook Pro's are really high end MacBook's! I'm praying we get a real working pro's MacBook Pro this year.
The real Pro's require USB-A & MagSafe. Don't get me wrong! USB-C is the future... but I'm not in the future, I'm here in the present! USB-A will be around for a long time & dongles suck! They also need 32 GB or RAM support, removable storage and bigger batteries.
The new iMac Pro has some interesting stuff (T2 chip & storage) that I would love to see in the MacBook Pro.
by
Add a comment
Add your answer
Colin Young will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 823
