Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Battery swapped but home button and touchID not working
Got that $29 battery kit, was excited to do the swap. Followed instructions step by step. Got it to power up and then... the home/touchID button doesn't work. I was careful not touch the home button or the surrounding area. Took it apart again and made sure all of the ribbons have connected correctly yet, nada :/. Someone explain to me what could be wrong? Thanks
Add a comment
Chosen Solution
Only explanation I can think of is the home button extension cable coming from the screen is either damaged or the connector on the logic board for the home button is damaged.
Score 1
1 Comment:
i resorted to activating assistive touch... well at least I have a brand new battery :/
by
Add a comment
I would look for a tear in any of the cables. Specifically the Home Button to Logic Board cable that is with the LCD/Digitizer connector, and the front facing camera connector.
I also surely hope you've tried the good and faithful hard reset.
Score 1
Add a comment
Add your answer
Binh Tran will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 63
