Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
985 Questions View all
Battery swapped but home button and touchID not working
Got that $29 battery kit, was excited to do the swap. Followed instructions step by step. Got it to power up and then... the home/touchID button doesn't work. I was careful not touch the home button or the surrounding area. Took it apart again and made sure all of the ribbons have connected correctly yet, nada :/. Someone explain to me what could be wrong? Thanks
Add a comment
Chosen Solution
Only explanation I can think of is the home button extension cable coming from the screen is either damaged or the connector on the logic board for the home button is damaged.
Score 1
Comments:
i resorted to activating assistive touch... well at least I have a brand new battery :/
by
Add a comment
I would look for a tear in any of the cables. Specifically the Home Button to Logic Board cable that is with the LCD/Digitizer connector, and the front facing camera connector.
I also surely hope you've tried the good and faithful hard reset.
Score 1
Add a comment
Add your answer
Binh Tran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
