Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
iPhone 7 BB CPU itself shorted
Has anyone had any Iphone 7 BB CPU shorted yet? I have done several 4013 and -1 repairs on these and recently took in 2 phones from a shop in Florida where I had a short on BBPMU_TO_PMU_AMUX1 and PP_1V0_LDO9 on one phone and just PP_1V0_LDO9 on the other. After removing the BB CPU the shorts went away on both, so I reballed and placed it back and shorts came back. Thinking I just made a mistake, I reballed both again and shorts came back a second time. I then checked those lines on the BB CPU and sure enough they are shorted within the BB CPU itself.
1. Has anyone else experienced this ...
2. I have NAND Programmer(s) but nothing for BB CPU... Is it even possible? Or does anyone have a programmer to reprogram new IC's?
Score 1
1 Comment
Now i have this problem... I re assembled phone
by
Add a comment
Chosen Solution
You might want to reach out to specialized vendors like VIPProgrammer or UnionRepair. They may be able to program a replacement BB if you give them the proper metadata. I have a similar issue with an iPhone 6 where I may need to replace the BB.
I also seem to recall a similar post on the FB group (MicroSoldering & Board Level Diagnosis), you may want to check it out.
Score 3
3 Comments:
@refectio I just received an answer from Vipprogrammer.com. I added a screen shot in my question...I was told that there is no programmer :(
by
Darn...
by
I have same problem here.. I re assembled phone :- )
by
Add a comment
Yes, we've seen three of these now. There are two different versions of the iphone 7 logic boards. It seems to be only happening on one version. The short is within the BB CPU chip itself. No way of fixing it that I know of. Perhaps data recovery, but I'm not certain at this point.
Score 1
Add a comment
I have seen lot of this case. Especially it shorted on BBPMU_TO_PMU_AMUX1 , PP_1V0_SMPS5, PP_1V0_LDO9. Theres no way to fix if u not found any caps shorted.
Add a comment
Add your answer
The Microsoldering Shop will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 30
All Time: 3,512
