Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Battery will not charge and MacBook will not run when plugged in
I had a major liquid incident on my late 2012 Unibody MacBook Pro. The good news is I replaced the logic board and the battery and everything was working well. That was until I realized the battery was not charging. When I select the indicator light on the side of the battery is flashes green rapidly. When the power cord is plugged into the MAC its stays a constant green and the MAC will not power on. Now that the battery is dead, the MAC will not power on at all.
I have checked all connectors and still no luck.
Anyone have any ideas?
Thanks
Megan
1 Comment
One other note, I have tried an SMC reset with no luck at this point. The light on the MagSafe adapter does not change. The green light on the MagSafe adapater is also dim.
by
Add a comment
1 Answer
Chosen Solution
Since you've already replaced the logic board, I'd replace the DC-In Board next:
MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement
Score 4
1 Comment:
I finally got to chance to install this and it worked. The only thing not working after all of these replacements is now the keyboard. Bummer!
by
Add a comment
Add your answer
Megan Heinz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 78
