Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Questions View all
Stripped screw during screen repair
While repairing the screen on my ipad 4, I was able to remove 3/4 screws securing the LCD to the aluminum frame with ease. The last screw will not move. I have tried different screwdrivers, a rubber band, the super glue trick, and am making no progress.
Please help!
Add a comment
I found this: How to Remove a Stripped Screw
Add a comment
i use a dremmel cutting tool to make a slot groove in the head, in order to use a larger slot screwdriver to remove the screw. this requires steady hands, and a dremmel tool to do, but if you have both, it works flawlessly every time i do it. (I do this every couple days)
Add a comment
Add your answer
ma sl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 822
