A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
SAC-001 No Power, possible fuse?
SAC-001 motherboard will not power on. Board looks immaculate, but nothing powers on. The power supply reads 5v and 12v outputs at respected spots, and works with other motherboards. Any perspective points or ICs I should check? Are there fuses or safeties on the board could have popped?
Score 2
Add a comment
Hello,
Did you found out what the problem was?
I got the same problem as you with the same motherboard (sac-001).
What i found was that when i plug in the power cord with only the motherboard, psu and heatsink the fan starts to spin for less then a sec...
Also i found that these points got power:
but there are probely more points..
Here's my question and more info:
PS4 1216A No Lights, No Beep
Add a comment
Hola que tal Tengo el mismo problema encontraron la solucion
1 Comment:
Unfortunately not. I had move on with buying a new board.
by
Add a comment
Add your answer
Sean Vinsick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 4,202
